Best first move… do nothing.
Usually. ![]()
Usually. ![]()
Do nothing. That is exactly what I have done since I saw the current firmware upgrades were available. ![]()
[smart-alec time]
Lies! If you “do nothing,” you’ll never know if something is actually wrong.
Looking on the forum and asking is more than doing nothing. ![]()
</smart-alec time>
Otherwise, I might power cycle a single device (not everything), or my phone.
Just don’t ever have ALL your devices do the same thing at the same time. Don’t reboot them all at the same time; don’t update their firmware all at the same time, etc.
But I always say reboot… 3 times ![]()
Prudent. ![]()
Is there a persistent auto-update toggle you have to turn off on the iOS app? I thought I saw someone mention it yesterday.
Well said, and I seem to recall @Newshound, @R.Good and @HDRock as among the first to recommend as much years ago… ![]()
Shout out to the first responders:
often among those of this bent:
upon whom my strategy of
somewhat depends… ![]()
I have never seen any setting for Auto Firmware updates. I have the Auto Update for apps turned off because if an app is screwed up I can not go back to an older version on iOS unless I sign up to be an app tester on Apple.
If I tap the cam to live view and it says new firmware in the pop up box I just tap don’t ask me again and cancel. I read the forums to see how many members post problems before I do anything else.
Thanks @Seapup I never noticed it on my V3, V3 Pro or WCO cams before. I checked and all mine show off. ![]()
