here is my question for the community, when i use my app to setup the recording parameters i get different options (see pic) one to drag the corners and the other to isolate squares. myquestion is how do i get away from the drag corners and switch my field to isolating squares?
The squares is the way it is supposed to be. It was previously changed to the squares on all the cams. But, some users are experiencing a random reversion to the old single box method. It has been reported to Wyze and they have made efforts to fix the issue but for some, the old method still persists. I believe it is specifically on V2 cams.
Here are some posts from other users also experiencing this who have reported it to Wyze. Linking their posts here will notify them so that they can post in with their experience and recommendations.
thank you for the quick response ![]()
Wyze is a great camera, and i have them installed at my senior relatives houses to keep a watchful eye about. i will keep following this thread although i know all great things take time to fine tune.
thank you again
| SlabSlayer Forum Maven
September 22 |
My experience so far is Wyze is ignoring the issue.
I recommend you get used to it.
