It has minimum width/height of detection zone, is there a way I can set it smaller? also curious why set minimum width/height of detection zone?
Thanks.
Thanks.
You can check out this wishlist item and add your vote, although I think there’s a bug in the iOS app right now that doesn’t allow you to make it as small as it should. I believe they’re working on it. Hopefully they’ll get it fixed before the next app update.
voted, thanks!
