Is Wyze thermostat compatible with manual heat to cool to cool switch?
(1st time using this system, so please bear with me…) My heating and cooling system is 22 years old. My existing Honeywell thermostat uses 2 wire ( R & W) with a manual heat- cool switch. I bought a Wyze unit with the C-wre adaptor, but I dont want to attempt installation (and be frustrated) if the Wyze thermostat isnt compatible. All of the info I’ve seen posted with two- wire installs is for heat-only units.
Do you have pictures of your current setup? 2 wires with AC is going to be pretty tough with the wyze, you’d really want at least 3 wires.
