The Box shows “Dimmable”, but the print on the bulb actually indicates “Do Not Use With Dimmers”
the bulb itself is dimmable from the app, but not with a dimming switch that lowers the power output to the bulb ( which the computer and wifi radio need at a certain level) thus using it with a dimming SWITCH could actually damage the bulb, but you can set up dimming from the app using schedules or triggers.
good catch on that, I never thought of how that could be looked at with that view.
Dimmable via software (via app): yes; dimmable via hardware (physical switch): no.
Welcome to the forums!
Ahhh…makes sense - thanks!
