Is Wyze 6e mesh router Pro compatible with Aircove VPN router?
Hello,
Wondering if my 6e mesh router pro is compatible with the Aircove VPN router? I have the mesh network successfully working with the Telmex router (fiber connection thru Telmex), but I’d like to add the Aircove VPN router to enable viewing of US channels, etc.
My current configuration is:
  • Telmex router connects to the fiber through a fiber connector and wire. Then, the Wyze router is connected to the Telmex router with a CAT 6 cable. I have two satellite Wyze mesh routers on different floors than the Wyze base router.
  • I was thinking I could add the Aircove by connecting it to the Telmex router and then connect the Wyze base router to the Aircove either by cable or wirelessly.
    –Is this possible? If not, any other options? I’m thinking I should probably remove the Telmex router from the mix by simply bringing fiber connection into the house by connecting directly to the Aircove, and then connecting Wyze base to the Aircove?
Any help is welcome!
Thanks!
