Is it possible to do this?
With multiple cameras inside and outside it would give a lot of piece of mind to be able to do that.
You may be able to set a rule with the trigger being HMS “Detects an Alarm”. Then the Action can be sound the Sirens on all Cameras.
Then another trigger for “Cancels an Alarm” then turn off Siren.
I have not tried it, but it may work.
@spamoni is correct.
I have those two rules and they do work. Any time the alarm activates on the hub and its siren goes on, even in test mode, all my cam sirens go on for 30s. Canceling the alarm turns them off.
But, there isn’t an action to add “All Sirens” since there are cams without sirens. You have to add each cam siren individually.
Thanks for the Validation. I may do that myself. ![]()
