I’ve about given up on Wyze getting my video lag back to an acceptable level using a Samsung J3 w/ Android 7.1.1. So I’m going to have to get a new device so I can see people coming up my driveway before they knock on the door.
I’m using Consumer Cellular and they offer the Samsung A20 w/32GB, Android 9 for $180.
Is that a decent phone?
I thought that was a low end phone but I could be wrong. Maybe you can.pickup an old S6?
That is a low end phone, I’ve got a low end wallet.
That’s why I was thinking of an old model but with more horse power. My spare S6 works great. My S4 works 80% of the time with Wyze. My new s10e works great but I had to mortgage the house.
What is the Android version on the S6?
I use Swappa all the time. Just bought a Pixel 3 XL for 260. Doing a project with it. But a nice S6 can be had for cheap.
The A20 seems fine spec wise. I don’t think you will go wrong with it.
Specs are pretty good and it’s Android 9.0
Sorry for the delay. I had to watch NCIS.
7.0.
Thanks for the tip.
Could be worth taking a chance with the a20. I just know S6 works. I would hope S7, S8, and S9 should work.
Maybe an A20 user will give a report.
Well what I want is a Note 10, But for the extreme difference in price I can get an A20 AND a couple of Samsung Galaxy Tab A’s.
/edit - Costco will be selling the A’s for $200 w/128GB of memory
Are Galaxy tab As any good? My old tab S3 is getting slow
My son drools and goes glassy eyed when somebody mentions the Note 10! He has a Note 8 at the moment. I have tried as he puts it, to tempt him to the ‘dark side’ with an iPhone. But he prefers Android.
I’ve a Note 8 already, A Note 8 GT-N5110 from 2013, stuck on Android 4.1, with a dying battery.
Might look into hacking it to Android 7.
This is a casual observation, not backed up by statistics.
It seems like when people write posts with comments like, “the controls are placed awkwardly, I can’t see the full screen, it’s not quite Android compatible, etc” and they are asked what phone they have, it is often a Samsung.
I have that. For fun, I dug it up and booted. Play Store doesn’t even list the Wyze app! But the battery is still 75% even after months being powered down.
I replaced it with a Galaxy S2 SM-T713, primarily because I like the S2’s better screen aspect ratio (like an iPad). I don’t know why they insist on 16:9 ratio, it’s bad for web browsing. They think all everybody does is watch movies.
Since S3 has been out for a long time, you might be able to get a refurbished S2 for cheap.
But then I anticipate will do some “upgrade” that will make the Android version obsolete. Something I buy new with Android 9 should be good through Android 11.
Unlike the previous Samsung tablets that hardly ever get Android updates, the S2/S3 series gets regular updates.
