Introducing Wyze Bulb Cam Pan Color - 10/22/2026
Introducing Wyze Bulb Cam Pan Color, the smarter way to light your space and keep an eye on what matters.
Get a 2.5K camera with 360° horizontal pan and 180° vertical tilt, AI-powered tracking for people, pets, and vehicles, and a bright, tunable full-color bulb with up to 1100 lumens, adjustable from warm 1800K to daylight 6500K, plus 16 million colors.
Install it in a standard E26 socket, connect over 2.4 GHz or 5 GHz Wi-Fi, and sync it with Wyze Bulb Color for coordinated lighting. With Privacy Mode, IP65 weather resistance, and support for up to 512GB of local microSD storage, Wyze Bulb Cam Pan Color helps you see more, light better, and stay in control.
Learn more:
and in Canada
Wyze Bulb Cam Pan Color (Canada)
This has potential. It’s a little expensive though. At that price, I’m more tempted to just replace the light sockets with a Floodlight Pro instead (well, maybe other than the front porch light).
I’m probably not planning to get one of these (my disposable income is limited for a while).
If someone gets this camera, can you try to make it spin more than 360 degrees? like spin around 2 times in a row in the same direction? Most panning cameras can’t do that, and they usually have a mechanical lock point at the back that stops them from continuing. I’m curious how Wyze solved this issue since this camera has a constraint of having to be screwed in, to the point where it can’t necessarily CHOOSE what counts as the “back” of the camera when it finishes screwing in to always be against the wall like you can choose with other pan cameras in the same way. It does show we can manually adjust one part of it to rotate to the front, but I expect that doesn’t change the gear positions. I’m sure they came up with something smart and that’s why it is more expensive than normal. I am just curious what kind of solution they came up with because I genuinely do not know. Maybe I will ask in the AMA.
I’d love to hear from anyone who gets this camera what they think of it and what their experience it like, especially compared to the others. It looks great. I love that it is brighter, can do Cool colors, and uses color and can control the existing color bulbs! That’s such a huge upgrade over the previous model IMO! I might get one eventually. I’m even considering getting them for some of my recessed lighting sockets or indoor lamps in the future.
