Has anyone installed the Battery Cam Pro outside under their soffit? If so, any issues?
Looking for any pros or cons before I decide where to install.
Thanks in advance!
Thanks in advance!
One thing to consider is the lip or edge of the soffet as if you were to use the spot light or the IR light because the edge being to close may cause light blowback, making the camera view look foggy. Anything to close to the front of the camera, wall.in view, rain gutter etc will do this too.
I have it installed on my Soffit. Had no issues doing it. My only recommendation would be try and hit the wood cross beam. However, I connected mine directly to the soffit and it has been fine.
