Battery Cam Pro speaker holes
My cameras are all installed under the eaves (except one) and I’m not worried about rain, etc. But now I’m about to deploy a couple of battery cam pros. I see there are holes at the back and these are probably for the speakers.
Will rain be a problem? Will covering the holes with waterproofed tape matter? I don’t need the speakers.
I have had 2 battery cam pros outside. One mounted on a fence in full exposure and the other near the edge of the eves.
Neither have had any issues with rain or water entering them. Knock on wood. :grin:
All my cams have speaker holes on the back (I don’t have a BCP though) and never had any issues, even with ones that are tilted downward pretty sharply.
That being said, if there is no use for the speaker, covering with a good tape certainly couldn’t hurt. I doubt those holes are providing any sort of ventilation since then they would not be weatherproof.
