Is there any pole or stand that can be used with the battery cam pro to place it away from a house but face the house?
The battery cam pro (and all wyze cameras except the OG models) have a standard threaded hole on them. You can use any camera accessories such as tripods, pole mounts, etc with them.
Try searching “camera pole mount” or “outdoor tripod” or something. As long as it has that little threaded bolt piece the BCP will attach to it.
Note that on the BCP the threaded mount is on the back, not the bottom. Make sure whatever stand got get is able to accommodate that.
