I have seen in the forum that the 180 feature is not provided for the Battery Pro. It said that the mounting is in the centre of the back of the camera which is incorrect. It is closer to the bottom and therefore allows it to fit closer to the mounting surface - and eve in my case. In the absence of the feature is there a longer mount bolt available? This would provide sufficient space to rotate it the correct t way up
Will one of these work? There are also various length sizes on Amazon. Make sure it is 1/4” -20 thread.
That was my first thought, too. ![]()
Thank you for taking the time to poke around for an answer before posting! Welcome to the Forum, @rogerprc! ![]()
Hi,
I am the proud owner of a new Battery Cam Pro. It is housed inside a fake birdhouse purchased from Etsy. I really wanted to mount it upside down because that would make the battery door accessible for swapping batteries or resetting when I get error 305 connecting to it.
In my application, mounting it upside down would not be a problem since it is inside a box (the birdhouse). But not having the ability to rotate the image 180degrees is a problem.
Thanks
Unfortunately that model does not support image flip. It is not waterproof when mounted upside down, so if they offered that option in the app, people would get confused and they’d potentially be liable for damaged cams.
Yeh. Thanks. If the Battery Camera had a magnetic attachment for the mount like the old battery camera, it would be more convenient for me. I bought it because the old model was not available. I will make the best of it, just not a fan.
I believe it uses a standard screw size so there are probably magnetic mounts available out there that would screw into it (or could fashion one up)? Not sure if that would help or not in your situation.
I wouldn’t either. Mine is mounted upside down in an enclosed garage. ![]()
You’re correct! I was looking at the wrong cam!
There is no Rotate Image 180°. I deleted my post above. ![]()
Me too to avoid confusion.
