Can I access the camera my computer? I have the camera synced with my phone and tablet but I don’t always have them with me and would like to sync with HP computer.
Welcome to the Wyze community @janbuck19!
this is currently on the Wishlist!
You can also use a free Android emulator, BlueStacks. This will allow you to view the cameras on your computer, but it may be unstable at times.
So the shorter answer is “no”. You probably don’t want to delve into the workarounds. ![]()
i typed in the google playstore address bar ( bluestacks 2 , and about 25 or so apps came up? which app and what is the name do i use to download to my PC so i can view my wyze cameras on my PC? JP
No, it’s not an Android app in the Play store. It’s an entire virtual environment you install on a PC. It pretends to be an Android device and you install apps inside.
I wouldn’t go anywhere near it. There is talk of malware and excessive system demands. But I don’t know, I’ve never used it.
Even if it’s safe and effective it’s a level of complexity not suitable for many people.
