My Wyze power adapter that came with the cam has failed. I cannot find a replacement on the Wyze website. Where can I get a Wyze brand replacement? Or can someone recommend a non-Wyze replacement on Amazon?
Thanks.
Thanks.
Almost any USB wall wart will work as long as it is rated with enough current. You message title says V3, but it is tagged as Pan v3. The original wall wart for the V3 is 1 amp and the original for the Pan V3 is 2 amps. Both of those are higher than need be, but you won’t go wrong with that. A gillion available at your local WalMart, other stores or Amazon.
Thanks
