Image rotates 180 randomly
After updating to 4.17.4.394 my outdoor cameras rotate the image 180. If I use the settings to rotate it back it will rotate correctly. That is until I go back into the app.
I am having the same issue. Same firmware.
Just purchased this from home depot. set it up, updated firmware and im having same issue. dont know what firmware im on but it says up to date. would love to hear a fix is on the way.
I still waiting. This flipping is also triggering the motion alert.
Still waiting on any info on this issue.
If this is any help to the software guys, I have five of these camera’s, two of them are on a power source via the usb connection and those two don’t invert 180, The three on battery only, do…
I hope there is a fix soon, it’s aggravating now…!
thanks…Pete
So, I noticed there was a beta firmware update for the outdoor cam. It fixed the rotation issue. Not sure when it’s going to come out of beta, but they seem to be working on it! Firmware was updated a few days ago.
This is fixed in the new beta release, It will take another week or two for it to get out of beta. If you need it sooner you can join the beta and update. I have not heard of any large issues arising in this beta.
Thanks
Pete
