I'm using the Cloudedge app for my Wyze cameras
I can’t access the SD card in my cameras. I also can’t easily delete videos that have accumulated on one of my cameras. Any help would be appreciated.
You would need to reach out to that app’s developers. Most of the 3rd party apps can’t do SD card access, change settings, etc, you need the official Wyze app for that.
Cloudedge won’t be able to access the SD cards. I assume you are using something to pull the RTSP streams from the cameras to integrate them into Cloudedge? That will only give you access to the Videostream. You might get a few other settings options through the MQTT stuff, but it absolutely can’t support the SD card playback, only the live view. Some app developers have also been able to integrate the Cam Plus recordings. But in general, the idea with your integration to Cloudedge is so you can tell Cloudedge to Save videos to a local harddrive on your computer or NAS instead of using the camera’s SD card.
I would still leave the SD card in the cameras as an extra backup, just know that cloudedge won’t let you view it.
