Okay searched forum and not able to locate this specific info.
I would like wyze open/close sensor to change smartthings virtual sensor. I see virtual sensor as a trigger and wyze sensor as trigger but am unable to make virtual sensor action. If wyze opens then open virtual sensor, however I am unable to select virtual sensor. I thought it was a pretty simple recipe, lol.
I do this with virtual on/off for lights. If motion detected on wyze motion sensor, turn on kasa lights.
Thanks for help.
I use SmartThings with WYZE and so fast the only easy I have been able to achieve this is I have the WYZE motion sensor trigger a virtual SmartThings switch. Then using WebCore I have the virtual switch trigger motion on the virtual motion sensor and do anything else involved.
Thanks Jason, seems like a long way around,
. I wish for smartthings integration or at least more options for via ifttt. I have voted for wishlist smartthings.
That’s great, I was just going to direct you there, seamless integration would be much better, until then I use the long way, can’t beat the price of WYZE so I make it work
