Ideas for Wyze Cam V3
About 10 years ago before I retired I was an instructor for the Army and part of one of the pieces of equipment we were fielding was a rangefinder shaped like a radar gun. We used it for measuring areas of pavement, bridges, size of buildings etc, We would be on a field training mission, usually on a Army installation, and be measuring things near a road. We were constantly hear drivers slamming on their brakes so they could slow down.
But to Omegan - I think a V2 or two could be used to collect data or relative speed for evidence to the police that they need to set up a mobile speed trap.
Hi,
I wanted to suggest to you that you create a 3rd type of camera, one that contains more powerful lenses and allows one to clearly see objects at 20m (8mm lenses) and 30 m distance (12mm lenses). Price would be higher, yes true, but it would serve a specific group of people that would like to install your camera to see far away objects. Appreciate if you can evaluate this option for a future product.
If you search around Tips and Tricks several people have swapped lenses.
Hi, thank you for your tip. I will read about it. Thanks again :wink:
There are some great requests here but one of my biggest hardware issues with the V2 are the IR emitters. I would love to see the V3 use … 940nm emitters so that I don’t have random red eyes looking at me as I walk around the house at night.
hello Team,
please
for improving the availability of cam when there is lan network outage. Bakckup on 3G/4G network via a wifi on Tethering
for : cam pan :
on one single pan cam,
add the possibiliy to declare several wifi network on cascading,
wifi #1 , normal
if wifi#1 go down, then the pan cam go automaticaly on backup network on wifi #2,
backup is’usefull in case wifi #1 is’down
require the possiblity to have servral wifi network configured on the same time
use case : wifi-1 : normal DSL connection
wifi-2 : backup : Tethering on an android device
thanks for help
Obviously some are easier than others. First and foremost, I think Wyze should focus on continuing to be a budget camera with great features. Keeping that in mind, they probably can’t implement EVERYTHING on the list. But here’s my shoot-for-the-moon wishlist.
  1. Local hub
    I saw somewhere that the average Wyze user has 1.9 cameras, and I would assume that number is increasing. If you include other Wyze products, it obviously becomes even higher. With that in mind, I think a local hub could streamline things and even make things cheaper/more capable. Since this has several potential benefits, I want to list them individually:
    a.) Offline use of cameras
    b.) Centralized offline storage of video footage. (An external drive could be plugged into it.)
    c.) Much cheaper for users with multiple cameras since there’s no need for multiple SD cards.
    d.) Video storage is effectively limitless
    e.) Could get rid of MicroSD on cameras, saving manufacturing costs
    f.) External processing could occur here. (Also saving manufacturing costs)
    g.) Built-in Sense Bridge
    h.) Possibility for WiFi devices like bulbs and plugs to connect directly to hub, instead of your router? Schedules could also be saved here, so that everything works if your internet is out.
  2. Modular EVERYTHING
    Let’s make everything modular. That lets users get exactly what they want/need at the best possible pricepoint. The most basic building block probably includes the camera lens, mic, WiFi connectivity, hardwired power, and processor/RAM/logic/etc. Want two-way communication? Great, buy this snap-on speaker block for $5. Need IR illuminators at night? There’s a block for that! Want to use a MicroSD card? It snaps right on. Need a backup battery? You can choose from 3 capacities! Want to change the color? The faceplates snap on and off! Modularity keeps manufacturing costs low and lets users get exactly which features they want/need. It also allows Wyze to add new features down the road without needing to change the core hardware. And the base model could be offered in a couple configurations, too. Perhaps a 1080p and a 4K base at different price points.
  3. Small backup battery
    I already mentioned battery as part of the modular idea, but if that doesn’t happen, a small backup battery would still be great. It could even be something the users need to provide on their own, like a watch battery. Just enough power to provide a few minutes of recording and connectivity in the event that it loses power. This is mainly for peace of mind in a theft/burglary situation.
  4. Larger backup battery
    Regardless of whether the larger-scale modular idea gets implemented, a bigger battery would still probably make the most sense as a modular expansion. Something that allows the camera to run in a low power mode for extended periods of time, or in full-power mode for a few hours. I listed this separately because I don’t think it necessarily requires “modular everything” to implement it.
  5. Larger camera sensor
    Self-explanatory, I think. Sharper images, less grainy. To whatever extent this can be improved and remain economical.
  6. 4K support
    Would be nice, but if choosing between the two, the upgraded sensor would probably improve image quality moreso than 4K
  7. Black/white option
    If not doing modular faceplates, the two colors would at least be nice.
  8. WiFi 6 (802.11 ax)
    Realistically, this is so bleeding-edge that I’m guessing it’s expensive to implement, and therefore unlikely to be included on a budget camera for a few more years. But it would certainly set Wyze apart and future-proof the cameras a bit more, especially for people with crowded smart-homes.
  9. NAS support
    Not super necessary if #1 is implemented, but if it’s not, this would be an alternative that could serve a similar purpose for video storage.
  10. More AI features
    Another one that probably isn’t hardware-specific. Basically, it would be great to expand on the awesome “person detection” feature. I’d love to see moving vehicle detection, perhaps animal detection, facial recognition, vehicle recognition (FedEx? Mail? Your own vehicle?) etc. Teachable AI would be the ultimate dream. Basically, the ability to tag important vs unimportant motion and let the camera figure out the difference. Even taking actions based on teachable AI! When I’m not home, I could teach the camera to recognize when my dog jumps onto the couch and blare a siren at her until she jumps down! (To the extent that those features rely on processing power, that may be another potential benefit of a local hub.)
  11. More integrations with more services / better integrations with existing services
    Let Wyze Sense trigger routines in Alexa. Integrate with HomeKit and SmartThings. Ability to view cameras on as many third-party devices as possible. (Roku? ChromeCast? AirPlay?) Etc. etc. The more we can do with our devices across platforms, the better. :slight_smile: And the more Wyze will expand its potential customer base.
A 1/1.8" Starvis+ , 4K sensor is currently the benchmark standard. However, I fear one could be too expensive to integrate into a Wyze.
I doubt they’ll move out of the “budget” sector, so that’s why I said “To whatever extent this can be improved and remain economical.” Although if they were to implement the idea from #2 (Modular everything!) it might be easier to make different versions, and people can just upgrade the features they’re most interested in (Including the lens/sensor/etc, perhaps)
I feel like this would be amazing to have. I want my cake and eat it too! But yes. RTSP with all the current features would be great.
I live in an apartment with a common entrance - the place is great aside from packages getting stolen occasionally, and management has been hesitant to install anything… A PO box is an alternative, but can be a pain.
It would be awesome if Wyze would release a flatter or less conspicuous camera for people who don’t want to seem like creeps recording their neighbors. I looked into the original Blink camera, which isn’t tiny, but due to its shape is a bit more hidden than Wyze. The drawback is they don’t seem to have continuous recording. I have a wyze from my old home where it was a bit more acceptable to have a camera in the window. Would anyone else be in favor of a smaller camera, maybe that’s battery powered?
No battery-powered camera will offer continuous recording. That’s not really possible. The power consumption is too high. Technically, you could do this with a Wyze Cam if you want to get a large enough battery bank and swap it out every day. But that sounds like a giant pain.
Are cameras explicitly disallowed in your apartment community? Or you just feel like no one else has them and you don’t want to be the odd man out? For the record, I don’t assume people with a camera in the window are “creeps recording their neighbors.” I assume they want to keep an eye on things and deter crime. ¯\_(ツ)_/¯
My V2’s will run about 23 hours on a 10AH battery, like the https://www.amazon.com/Samsung-USB-C-Battery-Pack-Silver/dp/B07N6YWNKF/ref=asc_df_B07N6YWNKF/?tag=hyprod-20&linkCode=df0&hvadid=344108281580&hvpos=1o1&hvnetw=g&hvrand=16447042689398313035&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008139&hvtargid=pla-757399858289&psc=1&tag=&ref=&adgrpid=73225757470&hvpone=&hvptwo=&hvadid=344108281580&hvpos=1o1&hvnetw=g&hvrand=16447042689398313035&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008139&hvtargid=pla-757399858289
which I’ve bought for $16@.
Yes but most battery powered cameras offer times between charges of weeks not hours. They do this by NOT offering continuous live recording. Think Blink and Arlo and Ring. Personally I prefer the continuous recording model (would really like it if they could record to a NAS) because I don’t trust motion sensors to catch every event.
Battery powered is not a dealbreaker for me. I’d be fine with a plug-in camera similar in size to the Wyze sense, even if it sacrificed certain qualities, if it had continuous recording.
Right. That’s why I mentioned that as an option, but that’s probably a dealbreaker for most people. If you’re putting a camera somewhere that’s not convenient to power, odds are pretty good that it also won’t be convenient to swap and recharge a battery pack every day or so – Not to mention that you’d need at least two of them in order to keep it going nonstop, and that battery capacity degrades over time, especially if you’re cycling it EVERY DAY, so you’d have to replace them sooner than you might think.
How often are you willing to change the battery? Understand that the battery itself will already be bigger than the existing Wyze Cam in order to power continuous recording for 24 hours. The camera itself can be Wyze Sense-sized, as long as you don’t mind that it’s connected to a giant brick next to it.
You brought up the Blink camera as a size reference. Just so you understand the energy consumption reference, a continuously-recording Blink camera lasts about 5.5 hours on two AA batteries. (Continuous recording isn’t an option with Blink, but that’s how much actual video you get, and they’ve optimized the heck out of that thing to make it use as little energy as possible.) So, to run a Blink camera all day, you’d need about 9 AA batteries. (and again, they’ve SPECIFICALLY optimized everything about that camera for low energy consumption.) And frankly, that’s best-case scenario. That’s using non-rechargeable lithium batteries, which are much more efficient than your rechargable ones. With a rechargable battery, you’d probably need 10 or 12 AAs. And keep in mind, battery capacity will drain over time, so you probably want to overshoot the 24 hour mark anyway.
Now do you understand? If you want a battery-powered continuously-recording camera, the form factor will not be small. Period. And you’ll probably need to swap the batteries out at least once a day, if not more.
Within the bounds of current battery and sensor technologies, continuous video recording will drain any reasonably sized battery in less than a day.
For reasonable runtimes of a week to a month or more the device needs to be heavily optimized and only fully powered up in response to defined “events” usually via some form of motion sensor.
Barring a breakthrough in either technology it will remain so.
1080p @ 60fps would be great.
1080p @ 30fps would still be good.
that’s my biggest issue with them… low frame rate.
i also wish the app was smoother when toggling back thru recorded video. it jumps back on the timeline, but then starts audio at least 30sec before the video catches up.
faster frame rate & smoother playback please.
I said battery powered is not a deal breaker, meaning it’s not completely necessary, and understand that battery consumption prevents wireless devices from continuous recording. I get that a cord / plug-in takes away some of the benefit of it being small, but that’s not a huge deal to me personally.
