We use a camera (preferably Cam Pan) to monitor horses in their stalls when they need 24 hr monitoring. Has anyone seen something like a clip mount so we could move the camera from stall to stall or to our horse trailer as needed? Anything temporary so we can move the camera as needed would be helpful. Thanks!
I am not sure about the Pan Cam, but many Wyze cameras have a magnetic base. You could attach large washers in each stall and move your cameras as needed.
Great idea - thanks!
The L-bracket idea looks really practical, and the magnetic base makes moving it much simpler. For a temporary set-up, I would start with one camera in the spot you use most and test the view for a few days before fixing anything in place. That way you can see whether the angle works before drilling more holes.
Great advise on testing location before drilling. My v3 is upside down because i drilled my hole alittle higher than i wanted. I flip the image 180 degree in the Wyze App to make it work for me.
Welcome to the Forum, @PALS! ![]()
I don’t know about the older Cam Pans (v1, v2), as I don’t have any of those, but I don’t think Cam Pan v3 or Cam Pan v4 have magnetic bases; however, if you’re considering mounting steel washers to various points where you want to stick Cams, then you could maybe try something like these magnetic mounts for those Cams without built-in magnets. I’ve seen other users describe decent results with those kinds of things, though I haven’t personally used them.
For stationary Cams that do have magnetic bases and include a steel mounting disc in the package, I’ve used 3M Command Poster Strips to attach the disc directly to a surface (window frame or even directly to glass windowpane) and then just stuck the magnetic base to that. This is how I mount Cams to some windows without using a specific Window Mount. I’ve had a Cam v4 mounted to the stationary pane of a sliding glass door this way for over two years now as a means to get a view of my deck.
I’m late to the party but if you look on amazon there are plenty of stick on neodymium magnets (very strong) that you could attach to the bottom of the cam, on the disc that rotates. I’m assuming around a barn/stalls you can find a metal surface to then stick the cam on?
