Hi, I live in Canada, and the monitor service does not work here. I use several Wyze devices on the app, and want to buy a water leak sensor, but cannot buy the hub without a monitor service which doesn’t work in Canada, which means I cant buy a hub, which also means I cant buy a water leak sensor. It is a circular reference …
Why can’t I buy a hub separately without a subscription so that I can use other Wyze products using only my WIFI ? It seems that you are eliminating a lot of sales by forcing a subscription that doesn’t work outside the USA.
Please respond. I really want to use as many similar products as possible, so that I don’t have multiple apps to control various devices in my home.
