How to use Wyze Motion, Contact sensor with Google Assistant? [Edit: removed IFTTT]
Is there a way to use Wyze Motion, Contact sensor with IFTTT/Google Assistant?
Unfortunately not yet, this is due to Google not allowing access to that part of the APi.
What are you trying to achieve?
Both types of Wyze sensors can be used as triggers in IFTTT. As mixonepa indicated, they do not work with Google Assistant at this time.
Don’t have anything particular in mind
