How to update Firmware on Wyze Plug 2021 Version
How might I update the firmware on the Wyze Plug 2021? Since I installed them a few years ago new firmware was released at least 8 times but the App thinks they are up to date.
This is the current version: 1.2.0.233 (January 3, 2023)
What version is on your plugs?
All firmware updates on plugs are OTA thru the App.
UPDATE: Plug Firmware Versions can be checked and verified for the model (Pre-2021 “Original”, 2021, and 2022) on the Wyze Firmware Page: https://support.wyze.com/hc/en-us/articles/360024852172-Release-Notes-Firmware
Aha! After reading other posts Re plugs, I determined that the plugs in question are the original version and have FW 1.2.0.80 which is the latest version for those oldsters. One of my newer versions of plug, a V2, has FW 1.2.0.233
And it appears that the only way to update plug FW is through the App which I suspected was the case.
