How to Transfer Wyze App camera settings to Wyze App on a new Phone?
I have used the Wyze App on an Android phone for a few years. I have 2, v3 cameras, 1 v3Pan Cam and 1 Wyze socket. I do not have the cloud system just the cameras linked to my phone app through the WiFi.
Now I have a new Android Phone. I have installed the Wyze App from the Google Play Store. How can I transfer the camera setup information to the new phone?
When I start the new app it wants me to go through the setup process like I was installing a new camera. You know, when you press the SETUP button and wait to hear “ready to connect”. My cameras are already installed, isn’t there a way to transfer the setup information from the old phone to the new phone.
If I do the full setup again with the new phone is the old phone and app going to be unlinked to the cameras?
When you install the app, you needed to create a Wyze account. The information and cameras are saved to Wyze.
When you add the app to any other device, make sure you log on with the same account information as you did before. This will beacon out to Wyze, verify who you are, and the provide the Wyze devices you registered or setup.
You need to have Internet access to do this.
I found the problem; I had two different log-in credentials for the Wyze app. When I log-in with the correct credentials it all works.
