How to tell when shortcuts are enabled
I have created a Cam shortcut to turn off notifications for all devices. When I select the shortcut, it pulses once and that’s it. I can’t always remember which ones I have turned on or off. The icons never change to indicate whether or not they are active.
Is there a “shortcut” to verify which shortcuts are enabled? Or any way at all?
Welcome to the User Community Forum @9826454!
There currently isn’t a visible way to know if a shortcut button is on or off, mainly because they are not toggle buttons. They are essentially fire and forget buttons. Press this - Do that. It executes the command you set and then waits for the next button press.
But, you don’t need a rule shortcut button to silence notifications for all your devices. That shortcut button is already provided for you.
On the home page, there is a bell in the upper right.
Pressing it will silence all device notifications and put them to sleep :sleeping::
So, when you run your shortcut, you should see the bell with the zz’s.
This is great, that answers my question!
