Noob here loving the cams so far, I qwas just wondering about turning off and on rules I have 3 shortcuts for rules are they all active? When I touch one it flashes is that activating/deactivation if somaybe wyze could add an on off color to know which rule is active.
If you have a shortcut showing across the top of the app home screen, it is active. It will only execute when you press the icon for that particular shortcut. They don’t operate like the Schedule and Device Trigger rules which can be automated. You must press the button to activate it. When it does the flashing for a second it is actually executing whatever commands you have given it. So if you see the icon, it will run if you tap it. Only way to remove the shortcut from the app screen is to delete it. More Info On How to Use Rules
