I am using the pro version but I had no issue when testing with the free version.
You do not need to use Apps2Fire to side load TinyCam. Just search for TinyCam on your amazon device and it will show up.
Just spent 15 minutes reconfiguring my cameras on TIny Cam Pro on a new FireCube. The export /import to the cloud is so much easier. Been using the TinyCam for years and never thought that was what the export/import did. Thanks for documenting this.
seebeewgmail-com Great write up on how to set up TinyCam and the web server. Recommend adding the following to the Troubleshooting tips for the users that have trouble figuring out the Wyze Channel # for a camera or why a camera stopped working when they added a new Wyze device in their app.
After installing the first camera in Manage Camera, For any Wyze camera , go to “Camera Status” at the top of the page. Press. It will show stats on the camera. Scroll down to “Advanced Info:” - Wyze devices: It lists the Wyze channel # 1, the camera name and MAC address, then the rest of the Wyze devices. So now you have a list of the channel numbers and the camera names to chose from when adding the next camera. Or it becomes obvious that the two new Wyze plugs which you just added became channel #1 and #2, and just incremented the channel #'s for the cameras.
So you can renumber the camera’s or move the new plugs below the cameras in the Wyze app to get the original numbering back.
I enrolled in the Beta program. After the latest updated tinyCamPro is reporting the same error.
Hi, did you get this issue resolved for accessing wyze cam over Tinycam? I am getting the same error.
I believe that the channel number would be the order you see your devices in your app list.
See this post:
As @foxminion04 said, it’s the order of the cameras in the Wyze app.
When you get the first camera set up, go to Check camera and you’ll get a list of your Wyze cameras.
Set Camera UID. This will prevent cameras getting the wrong name if you change the order in the Wyze app.
Did you set the channel to 5?
Do you see your cameras listed under Check camera for any Wyze camera?
