Are there any iOS solutions? Tinycam is only Android iirc.
Sorry, none that Iâm aware of. Iâm an Android user. @Loki is an iOS user. Maybe he knows.
I donât know of any. I asked the TinyCam developer about whether theyâre planning an iOS version. The answer I got back was essentially ânot at this timeâ. I can think of several reasons he might not be interested⌠Doesnât know and want to learn the iOS development environment. Doesnât want to pay Appleâs 30% tax. Maybe others. I guess all we can do it hope enough people as him that he decides itâs worth it.
Iâve tried loading Virtualbox on my laptop, but itâs not happy with something. Without it, I canât load TinyCam.
Good morning! This voice whispered to me in a dream:
âDonât trust TinyCam.â because donât trust anyone you donât know with your Wyze credentials (because they are the key to your lock of privacy/security.) Having said that, we know you will, and we wonât prevent it, so judge TinyCamâs trustworthiness based on its online reputation (established on reddit forums, etc). Given the dearth of criticism TinyCam has received on the forums over >1 years, we would say TinyCam is trustworthy, but we canât, because liability, deniability, etc. Thanks for buying WyzeCam!
(Iâm gonna disarm the two-way audio function. On principle.)
âŚand I thought I had weird dreams.
Time to wake up! You do realize google firefox and safari browsers listen to you while your on your computer and incorporated it into their search algorithm so they can serve up ads that you werent even searching for
Maybe for you, fresno. Iâve got DNT set to 1.
Currently testing tinyCam Monitor Pro on the ânext to cheapestâ Android âTV Boxâ (note: not real Android TV OS), found on Amazon.
Specs: S905W chipset, 2gb RAM, H264HW decoding supported. I chose the particular model because it has an Ethernet port. Plenty of stability risks going on without adding WiFi issues to the mix.
Approximately $35. Why go so cheap? Well⌠It doesnât make sense to get a $100 to $300 server for a $20 camera, does it? This is a proof-of-concept for ActionTiles Customers. We want to know what the lowest priced feasible solution is. I think the next meaningful step up is an S912 (?) box in the $90 range: But at that price, using an âoldâ phone, tablet, or hacking a Fire Stick might be a better option.
Starting simple:
- Not rooting, but avoiding extra bloat too.
- Using alpha vnc lite (because box is running âheadlessâ - no TV monitor), which does not require root.
- Both tinyCam and vnc are set to start upon boot.
Results so far?
- Testing with 2 Wyze Cams
- Tested for a while on WiFi and seemed rather stable.
- The âAuto Start Web serverâ on boot option frequently toggles off. Why?
- Even after boot and manually starting tinyCam, the Web server often does not remain toggled on.
- Using âPower safe modeâ seems to substantially increase stability, but frame rate is 0.3 Hz (one frame per 2 to 4 seconds; not 3 to 10 frames per second). Thatâs acceptable to me, Iâd like at least 1 Hz.
Next Steps?
- Rooting and removing the built-in Apps from the Box to ensure maximum resources are available.
- Might try an alternative ROM. There seem to be some good ones.
- I want to test this with some LAN RTSP camera(s) too. And try at least 3 concurrent Wyze.
- Goal is to see if I can reliably serve 4 cameras, even if the frame rate is approx 1 frame per 5 seconds.
Ok, I realize this isnât a Tinycam forum per se but maybe someone here can help. I was using tinycam on my phone to see the wyze cam in actiontiles. I wanted something that would stay fixed at home so it wouldnât go off everytime I left the house. So I put Tinycam on one of my shields.
I set everything up the same and changed the IP address in tinycam and it will not connect to the new server on the shield. If I change everything back and turn on the webserver on the phone, it works in actiontiles. So it has to be something in the Tinycam settings on the shield.
I am using the guest access and set that up the same as the phone. The only thing I can see that is different is this,
On the phone, the last of the IP address was 113. I had the 8083 port forwarded and in the list it says that port is mapped to 124.
On the shield, the last of the IP address was 124 and if I map the 8083 port it is mapped to the same address. That is really the only difference at all that I can tell between the two settings.
Anyone have any ideas?
And by the way, I can see the camera in the Tinycam pro app on the Shield just fine. It is working as far as that goes, it is just the fact that actiontiles will not see it. And like I said, I donât think it is an actiontiles issue because if I change the address in actiontiles to the webserver on the phone and turn the webserver on the phone on, actiontiles will see it. Literally the only thing that is changing when I do that is the last three numbers of the IP address to reflect the different server.
Nice write up tgauch . I was using on a stock fire stick. It ran but not great. A stripped down rom would be perfect. I am not looking to spend that much time on the stick. Now I am using an Nvidia Shield. Runs great! If I was not using a home media center I would run this strickly for Wyze and TinyCam. The Android version on Nvidia is so clean and fast.
It sounds like you have every things correct. I am not familiar with action tiles but a quick look at seems really cool. Will need to check that out. Sorry I cant help
this information can help you ,go to youtube and look for taylor tech and look for wyze and action tile
i just noticed that tinycam pro keeps the password of wyze in plain text!!!
Try deleting the .xml file it creates for itself when you set up cameras. itâs probabably still trying to read that
Iâm not sure if this has been mentioned. I am on tinyCam version 14.1.1. Since the excellent set-up tutorial was created by seebeewgmail, the camera setup needs to be changed to accommodate the newest version. Under âCamera settingsâ and under âProtocolâ, select the âCloudâ protocol. Otherwise, I could not get the Wyze camera to work (video failed).
I purchased 18 Wyze cameras (12 cam v.2 and 6 Pan Cams) to replace an existing security DRV system I have. I have no problems viewing on camera one at a time on the Wyze app and TinyCam. I setup TinycamPro and I have no issue setting up each camera. The issue comes in once I try to view more than 3 cameras at one time the feeds randomly start dropping and coming back on. I also notice connectivity issue on the network when I try to connect to more that 3 cameras at one time too. Printers cannot be connected to, file coping takes 5 to 10 minutes for small files (1 to 5 megs), browsing the web takes a long time to pull up pages. I have reached out to Tinycam developers and they point their firgure at Wyze, I have asked Wyze support and they say it isnât them because I can view the cameras on the Wyze app with no issue but I cannot view more that 3 on the screen at one time so I cannot say this is a good testing comparison.
I got a separate wifi router (TP Link C900). I installed RTSP fireware. I have tried everything I can think of but it still comes down to once I connect to that 4th camera, the network crashes.
What would be nice is if Wyze had their own multi camera viewing so you can pull up 12 to 18 cameras at one time so we wouldnât need to deal with a 3rd party app.
Can I get any help on this please???
I have tinyCam Pro set up with 1 D-link and 8 Wyze cameras (6 V2, 2 Pan).
tinyCam is running on an Android TV box showing all 9 cameras at once.
I do get a lot of dropped signals from the Wyze cameras but itâs not interfering with my other network activity.
In the Wyze app, if you group cameras you can view 4 at a time in landscape mode and swipe between screens to view 4 more.
Have you got tinyCam doing anything other than viewing the cameras? ie; uploading video, motion detection or object detection?
I keep getting an error when trying to install TinyCam via Apps2Fire. âInstall failed no matching ABISâ - failed to extract native libraries, are you using the free or pro version of TinyCam?
