How to set the weight goal in Wyze Scale X
I have set up my Wyze Scale X, but something seems odd - I am not able to set my weight goal as the slider is greyed out and so I cannot change anything. I am using Wyze app v2.33.0(b159) on Android.
Any pointers on how to solve this?
I moved your topic to the Beta category as you are running a beta app and potentially reporting a bug.
The Weight Goal slider is supposed to be greyed out. You should see a thin blue-green marker in the center. Swipe the weight slider left/right to adjust the weight goal. The goal result is displayed above the slider and a lose/gain value is displayed beneath. Please post a screenshot of your Weight Goal page.
Did you click on the Reset button at the bottom, then attempt to adjust? After you have the desired weight, click Setup at the bottom.
The line is not quite distinct. I suppose it should be made bold.
As @R.Good mentioned, I discovered that if I press the Reset button, then I could move the slider to set my weight goal, which is calibrated against that thin blue-green marker.
The setting isn’t as intuitive as I’d have loved (I have another smart scale from someone).
The line should NOT be thin, and I suppose it’s also trivial to just let someone enter a figure on that page. I hope Wyze will do something about it.
