they do protect with them
What do you mean “protect with them”?
The Chime allows for connection to most, if not all, of the Wyze Camera’s and Doorbells. You can set them to sound when certain triggers are sensed. You can even set the type of sound you would like.
Is that what you are meaning?
Remember, this integrates with the Wyze App and Wyze Cameras.
amazon sent me right wyze chime did all of this.
FYI, mine shows up under doorbelll settings under the accessory tab.
DJ
Which Doorbell are you speaking of? If it is the Doorbell pro with the Required Chime, that is a different one. You need that Chime for the Doorbell Pro to connect to the network.
The New WiFi Chime will Alert on most any camera. It was introduced with the Wyze Duo Doorbell. You can now get this chime independently, when you click on the Chime in the Device List, you will be presented with the Volume Control immediately.
