How do you disable the emergency button that shows up when you hold tap the camera notifications , this button could be pressed by mistake so I please like to remove/disable it.
Try tapping the emergency button. It doesn’t call 911. It brings up your phone dialer prepopulated with 911. You still need to hit your dialer app’s dial button.
I thought Matt said that for iOS it automatically dials 911, but for Android it takes you to the dialer.
I haven’t tested it though.
Oh no… you’re going to make me fire up an iPhone! Hold on and I’ll be the guinea pig…
I can’t even get emergency calling from notifications working with iOS app version 2.50.9 (1). Probably because I’ve disabled mobile data and wifi calling. Not going to persist with this as I need to update this phone to 3.0.0.16 while I have it fired up.
