Turn off the base, insert the SD then start the base agsin.
I’ve shut off the Base station and turned it back on, didn’t help.
Assuming your SD card is good, it’s probably formatted to exFAT standards. Your outdoor cam and base require FAT32 standard. If you have only a MacOS machine, try running Disk Utility against your card. Format to MS-DOS (FAT) standard. Follow this if you have a Windows computer, V2/pan cam or USB>SD card adaptor:
That worked, thank you!
John
| Seapup Forum Maven
August 12 |
Glad you got it working! ![]()
This WCO has been a huge disappointment for me. Twelve second recording max. Even then it doesn’t get recorded to either scard.
I can’t tell you how many important events this camera missed.
I have 8 cameras and understand how they work. The WCO seems to do whatever it wants. Which is pretty much a whole lot of nothing.
