How to order more sensors and keypads after buying home monitoring system?
I am in Canada. I purchased the basic home monitoring system from wyze Canada. Now I want to order more entry sensors and keypads. I see no option to order just those on the site without buying another hub and annual subscription. Please help.
Canadians can’t order sensors without a hub through Canada yet…Canadians have to use:
And separate sensors aren’t yet available on there.
Wyze should update and change this.
Thanks. This Canadian site doesn’t let me buy sensors and keypads only
Yeah, I’m hoping this is just a temporary oversight and hopefully someone can get this resolved. I agree that you should be able to buy sensors separately since you might already have a hub, etc. If they are concerned about people accidentally ordering sensors when they don’t have a hub, then they should do something like a disclaimer you have to acknowledge saying that you already have a hub or something.
I am told this should now be fixed if you want to go on and try to order them again.
Sorry for the trouble.
Thanks Jason! That was a fast a resolution to happen on the first business day back after this was reported!
@TorontoTycoon let us know if it works for you now. Thanks for reporting this. :slight_smile:
