How to install Wyze Cam v3 cable weather boot?
When unplugging the cable, the boot popped off. It has a rib inside it, near one end. What is the right way to install it? Which cable end does it slide onto first? Which direction (with respect to the rib) does it go on?
The smooth bore end goes over the female plug leading to the cam first… All the way over the cam plug casing until the plug casing reaches all the way to the other end where it will butt into that rib. That way, the entire cam plug casing is inside the weather seal boot.
That rib serves as the weather seal gasket between the cam female micro USB casing and the male micro USB casing you plug into it.
In other words… Rib farthest from the cam.
Thanks for the concise answer!
