How to flash cam v3 connected to flood light?
My floodlight cam v3 won’t connect to network since last firmware update. I was going to flash camera like I have read in other posts, but not sure best way to turn camera off to flash it. Any suggestions?
Thanks
I suppose its a pain there since its hard wired. Unless you can somehow unplug the power only to the cam then you’d have to do it with 2 people (one at the power box) unless the cam stays off when you flip it on. I don’t know what it will do.
Could be fun or crazy fun :slight_smile:
Was able to get a friend to assist and flipped switch to turn light / camera off. I held button and they turned switch back on. Up and running on old firmware.
It doesn’t look like it, but the V3 is actually plugged into the PIR motion sensor module on the original floodlight with a micro USB cable. :slight_smile:
