How to change the sensitivity to motin settings
My camera is working great but it picks up the slightest movement of anything. How do I change the settings a little bit so that it doesn’t pick up movement so easily?
pull up a Live View of your Wyze cam, tap the gear icon in the upper right, select Detection Settings, adjust the slider bar under Motion detection settings Sensitivity towards the left (Low).
You can also create one reduced detection zone to possibly eliminate a problem area in your view.
