How to advance between recorded events in cam v4?
I have both v3 and v4 cameras. I need to view the events recorded on the SD cards of the cameras. On my iphone, the Wyze app for the v3 cameras allows advancing to the previous and next events recorded on a SD card using an arrow icon. I need to be able to do the same thing with the v4 camera, but I can’t find a way to do it. The v4 user interface has a vertical scroll bar, which is requiring me to manually scroll for events, which takes a lot of extra work if here are few events recorded (requires scrolling through hours to find the next event). How can I get to the next and previous event by tapping something in the v4 user interface like I can do in the v3 interface?
On the v4, while reviewing the SD card footage, tap the video and you’ll see forward and back arrows overlaid on the video, which will move between events.
Thanks a lot! That worked!
