I use individual bulb scenes all of the time. I have an old house with no light switches so all lamps are controlled individually.
I have Room bulbs grouped by room. I set up scenes to control all lights, and then I set up individual scenes for each bulb to control specific room area lighting as needed.
I also set up schedules to change the color temperature and then change not back at specific times to let me know what time it is during a busy party. to cue me to check the oven or start a meal course.
It would be nice to have an even dimmer setting. Maybe they fade over time but right out of the box they are very bright. Used in ceiling, one ceiling is pretty high.
I’m considering getting the bulbs, but need to know:
Are those times standard times? Are those time settings affected by DST? What I mean is that sunset time is going to change, so if I set a bulb to turn on at approximately an hour after sunset, will I need to keep on updating the setting, depending on the date?
The times are current EST
Until wyze comes up with something different , The way I have it set up I will have to change the times occasionally in my shortcuts when days get shorter and when DST changes .
I don’t have a problem changing it once in awhile, it is either do it this way or not at all
I have two Wyze bulbs and they go offline every three days. Right now they are offline and I cannot get them to reconnect I also cannot get remove devise to work. No problem with other brands.
How do i activate/change the WYZE bulb color tone/Scene via Google Home Assistant?
I am not sure as to the correct phrase syntax.
I do not see a setting in GA Routines to change the color temp or brightness.
Also, a thing i notice, the Google Home app, the color tones options are not quite right or match the WYZE app.
Ivroy= Cool (not not max cook k)
daylight = white (but kinda soft)
cool white = soft white
warm white = more soft white
incandescent / candlelight= very warm white
I find coordination with amazon echo way better than the google assistant. I grouped 4 bulbs together named north south east west in the living room cieling fand and call them group “living room”. I tell alexa renamed computer “computer turn on north bulb 1%” for use as a nightlight or “computer turn on living room 100%” when wanting bright. I generally keep it on white or sometimes soft white. same for 2 bulbs outside on the back deck. use one at 1% all night or off and if there is something that attracts the attention of the dog “computer turn on backyard 100%”. I use one for the bedroom and one in the maste bath choosing to just say “computer turn on bedroom” as I walk down the hall and “computer turn off bedroom” after I’m tucked in for the night. I have noticed a couple times the bathroom or bedroom on in the middle of the night. either I said something in my sleep, or the dog did, or they just came on themselves but it was weird. I do notice avter a power outage because the light switch is on but they were told to be off the power bump has them come on as if you cycled the wall switch. that may be the issue with people having the bulbs come on by themselves. I started to use sensors and it worked but the situation was not optimal for me.
Yes I agree…with IFTTT there are only 3 settings for color and 4 for brightness. We should be able to just pick between 1-10 or preferably 0-100%. The existing presets are not very useful especially when the bulbs are actually capable of going less than 25%.
Slightly off topic but Webcore/IFTTT to control the bulbs is a pain because you have to create a virtual switch in Smartthings for every possible brightness and color and then create IFTTT triggers for each of these to set the bulbs.
I only use the Wyze app to adjust brightness or bulb color if they are not set the way I want at the moment. I have them grouped so I usually perform the operation on the group. Occasionally I turn off a single bulb in a group when I am doing something out of the ordinary.
My Wyze bulbs are only part of my setup. I have a Schlage z-wave lock and a z-wave bulb and some zigbee bulbs on the way. I will adding other items over the next couple months but they will likely not be Wyze for the simple reason that there is no integration with Smartthings (ST) and it does not appear to be on the horizon. So I am using ST and webCoRE to control most things other than a couple simple Automations in ST.
Also, the single most useful feature of a bulb is being able to turn them on at sunset/sunrise (with a plus/minus about or a random variable amount of time) and Wyze does not have that. So for people who have a very simple setup and only Wyze devices, the sunset/sunrise are critical. For anything else, most people will be using a ST or other hub which gives them better control.
I have said this in other comments. Wyze make good quality, cheap hardware. Provide the basics for simple setups and focus your “control” efforts on integrating with Smartthings and other hubs.
