I just got a pop-up asking me if i wanted to upgrade firmware and accidentaly clicked “no.” How do I fix this?
Hi @mczonie No worries. From your app select the cam.
Hit the grear icon upper right, select Device Info, then Firmware Version
It should give you the option to upgrade there.
Let me know if this solution works for you.
Another option is to go to Account > Firmware Upgrade.
A better solution @angus.black! Thank you sir.
