Cam v2 won't upgrade
I have a cam v2 black on firmware 4.55.0.104. On app it states firmware is up to date (obviously not). I tried to flash latest firmware 4.9.9.3006 with sd card. Seems to go through the process correctly (flashing blue/yellow, reboot). But still old firmware. I tried hard reset no difference. Can still connect to camera. What now?
4.55.0.104 is V2 firmware when the camera has been flashed for use with a Wyze Car. As I recall, to convert that camera back to a standard V2, you must use the Wyze Car app to convert the camera back to standard. Then you can update it to whatever is the current V2 firmware (which is 4.9.9.3006).
Ohhhhhh…That makes sense now. Thanks for tha t.
