How do I remove the “Win $30 gift card” from camera view in the browser. Shocked that Wyze would even consider doing this.
It disappeared for me after I completed the survey and gave them feedback. If you’re using something like Incognito mode or deleting your cookies, then it might reappear. You should also be able to block it with something like uBlock Origin Lite in the same manner used to remove things like the Osano cookie widget if you’re really that concerned about it.
You can install as many web browsers on your device as you want. Try the Brave Browser and see if you like it.
Thanks for the tip!! I did the survey and it disappeared.
You’re welcome. Glad that worked for you. ![]()
For whatever it’s worth, I found that I was able to make the survey tab/link reappear if I logged into Web View using Chrome in Incognito mode, so its appearance does appear to be cookie related. If you clear your browser’s cookies, it might return.
