How can I let someone see a cam without the software? A link perhaps. That would be ideal as I want to post it on Facebook. Any other suggestions would be very appreciated! Thanks, Roy ![]()
If you are using RTSP and you open the necessary ports on your home router and setup port forwarding or an alternative addressing scheme you could share a link to the camera.
But if you are using the stock firmware anyone you share access with will need the Wyze software.
Thanks!
Roy
