How can I download 2.50?
Apparently I can load the latest version onto my version of android. Instructions said to use wyze app 2.50 , but I can’t find any way to get it.
Welcome to the community @JoeBobJenkins
Can you provide a bit more info here?
Why are you trying to load an earlier version of the App, is there an issue you are looking into?
It appears the latest release it: 3.3.6.626 (February 25, 2025). I have not had any real issues with this version.
However, if you are insistent on getting a different version of the app, you can always download the APK from a site like APKMirror. However, this is not a supported process as APKMirror is not run by Wyze. You would be loading the APK at your own risk.
Here is the link to download older Wyze APK files.
BTW, I am still on App version 2.50. All of my devices can run App 3.xx but I am of the mindset “if it ain’t broke don’t try to fix it”.
What version of iOS or Android are you using? To run the current version you need iOS Version 15.0 or higher, or Android Version 9.0 or higher.
All my older Kindle fire HD 10 tablets and a newer Max 11 cannot run 3,x and have to stick with 2.50. 3.x can be loaded but 4 cams are not streaming. If I click just one cam it will stream. I even factory reset my Max 11 but it still cannot run 3,x.
However, my latest 13th gen HD 10 can run latest 3.x and streams 4 cams without any problem.
