App for old phone
I now use iphone but I have an older android phone on my desk which I use to monitor my home. Two weeks ago, I had to do some clean up of that phone and regrettably lost the wyze app. Now I discover that Google Play no longer provides the app for my old phone. I assume that you still have access to the old 2.50vpk install package and I’m asking for your to provide the correct installer. My android was last updated on 12/22/21 with software update J737VVRUABUJ3. Can you help? Thanks.
[Mod Edit]: Email address removed.
[Mod Note]: Personal information has been removed for privacy and security reasons.
Wyze publishes the latest version of their application to the application store associated to your viewing device’s operating system. But you can find older Android versions of apps on “mirror” sites like APKMirror.
The most recent Android 2.50 Wyze app is located here on APKMirror (requires an Android bundle installer app to install the package): Wyze - Make Your Home Smarter 2.50.9.512 APK Download by Wyze Labs Inc. - APKMirror
This Android 2.50 app is one version older and requires no installer app. Just download the .apk file and sideload on your device: https://www.apkmirror.com/apk/wyze-labs-inc/wyze/wyze-2-50-7-487-release/wyze-make-your-home-smarter-2-50-7-487-2-android-apk-download/
Please note that the old Android 2.50.x and older app versions will not work with late-model Wyze cams.
I have App 2.50 working with my Wyze Cam v3 cameras on v3 firmware 4.36.14.3497.
When I update my v3 cameras to a newer firmware version that does not break functionality, I will then be required to use App version 3.xx.
Which phone is it? Perhaps you can give it a new lease of life with LineageOS??
