Home Monitoring Trends - no longer shows the Trends
I used to have access to the Home Monitoring Trends section in the Wyze app, where I could view my Home Monitoring usage history over months and even years, including the total number of hours monitored.
However, after a Wyze app update sometime within the last 2–3 months, the Trends feature appears to have stopped working. When I navigate to Home Monitoring and try to view data for different months or tabs, I receive the following error:
“Internal error occurred. The data couldn’t be read because it isn’t in the correct format.”
I’ve already tried the following troubleshooting steps on my iPhone
  • Cleared the app cache
  • Force-closed and restarted the Wyze app
  • Uninstalled and reinstalled the Wyze app
  • Have also tried usig Wyze Beta app
  • I don’t use any VPN
  • Tested on a direct internet connection
  • Restarted the Wyze Home Sense Hub
  • Restarted my iphone
Unfortunately, the issue persists.
Is anyone else experiencing this problem with Home Monitoring Trends? If so, have you found a workaround or received any updates from Wyze regarding a fix?
Attaching the error for reference.
The only thing left I guess is to reset the Wyze Sense Hub… I would really hate doing it as I need to pair everything considering the number of sensors I have setup :worried::worried::worried:
