I have been unable to find anything on battery type in the keypad, or how to change it.
Any help will be GREATLY appreciated! :>)
The keypad takes 3 AA batteries:
https://forums.wyze.com/t/wyze-security-system-impression/175412/3?u=seapup
Thanks much I could not locate this.
Have a GREAT day!
Rick
No problem Rick… glad to help.
How do you change the batteries in the Sense Hub?
Hello @DCHotard and welcome to the community.
Officially you don’t, it is a built in, non replaceable battery. My guess is someone will open one and find a way eventually
So then when I lost power for 4 days because of Hurricane Ida, and had no alarm, why does the website say “Battery Backup?” I had no alarm system. If I had known this I would’ve thought twice about buying this system.
It does have a built in battery backup, I am not sure how long the battery lasts before dying, it recharges while plugged in. To test you should be able to unplug and it will stay powered via internal battery.
