Home Assistant Integration
So is it certain this is local, no *cloud" and no logging in? If so, great. I guess the missing piece is getting the V2 bridge local as well.
Yes, doing it this way is 100% local for the sensors. The sensors connected to V1 bridge on a Home Assistant computer will not connect through the Wyze servers at all.
Currently it needs the v1 bridge. No logging in or credentials needed. Once you connect the Bridge, you can pair your v1 and v2 sensors. Josh’s piece of connecting the Bulbs, Plugs, etc, requires you to logon. I believe the issue was not with these and wyze is allowing that part.
If there was a method of connecting the v2 hub, that would be great. Have not found that yet.
Oops, just saw @carverofchoice responded. :slight_smile:
Hmm, wonder if ha-wyzesense can somehow handle the temperature and leak sensors too. They are not mentioned (well, nor is the surprise V2 compatibility; the whole project actually claims to be unmaintained).
So here is a quick test I did to see if I can get HA to trigger a Wyze Bulb (in Wyze) using a v2 Motion Sensor in HA.
Couple of items to note:
  1. Ignore the mess, the Wyze Vacuum is scheduled to clean and we pick everything off the floor. :slight_smile:
  2. When entering the room, you will see the bulb go on. that is the Test Bulb with Test Motion Sensor in HA.
  3. The Click sound is the Wyze Switch turning on as I have a Wyze Rule setup with another Motion Sensor.
  4. As I enter the Room, you can see the V2 Motion Sensors on the wall and when the indicator lights turn Red. The Top Sensor is the Bulb, the Bottom is the Switch.
  5. Even thought Josh’s site says switch, I don’t see the switch in the list. So I am still researching this.
But here is a video of a simple test:
I will see if I can add a Temp Sensor to the mix. Not sure, but will try
EDIT
Just tested a Temp / Humidity Sensor and it said it added it successfully and named it a Binary Sensor as “binary_sensor.wyzesense_macaddress”. However, it did not show up in my entity list.
So it sounds like we can apparently add the other sensors (temp/humidity, leak sensors), but nobody has added support for them yet so they aren’t yet usable in H.A.)
That is my belief as well. Maybe Kevin Vincent will add it.
Other item is that Josh’s integration currently does not support the Wyze Switch. The current Switch integration is to turn the cameras on and off.
Trust me your better off with Zigbee. At least you know they are going to work and stay supported no matter what. I’m done with Wyze. There had plenty of time and money to be able to add the small functionality of a main supported API but they won’t. Because they want you to use their app and pay for their cloud services when they know you can do better than cloud for less money with a NAS and some NVR software. Both have free options for. Anyway back to hacking away
The only downfall as I have mentioned before is that you loose your home monitoring when you oair them with the v1 se sensor maybe not a big deal but we do use and pay for it. I probably will cancel my home monitoring service and pair them locally though.
If you’re still looking for Home Assistant integration for the cameras, check out this plugin called “Wyze docker bridge”, all you have to do is login, start the server and then follow the simple instructions and I now have LIVE camera feeds in my home assistant and NO RTSP was required! No it’s not perfect but man it works great and took less then 10 mins to setup.
GITHUB: GitHub - mrlt8/docker-wyze-bridge: RTMP/RTSP/LL-HLS bridge for Wyze cams in a docker container
HA PLUGIN: Link to Supervisor: Add Repository – My Home Assistant
Thats a really cool project thanks for sharing!
I’d love it more if it gave us entities to turn on/off the cameras like this one I use currently does:
But I really like the RTSP function this gives which means I could finally move my V2s off the old RTSP firmware, especially with the snapshot function which is less taxing on the server!
Thanks again.
+1 for Home Assistant functionality. I like my wyze cam, the starlight sensor, the person detection, and the company seems good, but Home Assistant functionality is too valuable to lose it on all my cameras, lights, doorbell, etc.
You should be able to expose the functionality required for HA developers while still protecting your paid services and income streams, and designing the API in such a way that the servers don’t get bombarded.
Yes please. Integrations are what makes products valuable. Please add support for this.
+1
It goes on and on my friends, this is the thread that never ends…
Wyze is in a spot where their advantage is price. When someone comes along and recreates what they’ve done at a comparable cost but makes it more open for third party integrations they will easily take over the budget camera and smart home product category from Wyze. Not giving this attention is a short sighted move.
April '22 here - I’ve read the entire multi-year thread at this point. Wyze just lost a customer.
Signed up just to add my voice to this. Really like Wyze’s products but I’ve been holding off buying more or subscribing to their service because of the unknown support with Home Assistant.
I like having the local control to trigger other automations, but also like having the redundancy of the cloud service just in case something happens with HA. If I had to choose one, however, it’s local control/HA because companies can stop supporting products at any time for any reason.
Welcome to the community @JohnNS adding support to this is a great reason to sign up. Having Wyze support being able to run totally locally at all times with cloud as a redundancy would be awesome. I definitely support that. It is too often that the cloud goes down or has problems and then nothing works (smart lights, etc), so I would love local access for everything.
My guess is that I don’t think Wyze is considering an API until they first know what is going on with Matter. My understanding is that the first Matter stuff should take place in the late part of this year. Then Wyze’s focus will be on working with that, then if all is well, API could come after that settles down.
It’s really frustrating to not have an open API for this yet or an official integration for HA. I’m starting to write my own integration for Home Assistant at this point, but I’m worried because it’s using an unofficial SDK.
There are a few unofficial ones out there, but some were hamstrung because they were causing too much load on Wyze’s servers. I’d love to be able to track motion again on my Wyze cameras and see if my doors are open or closed in Home Assistant again.
It’s a dead point. They might write some limited support into future products but it will come with a cost to use. They just are not going to allow full local access and any use of thier servers they are going to want some $ for. As far as I’m concerned they’ve lost me as a customer and more. There are other better options for near the same price that also work reliably.
