Hearing sound event recordings
Hi
Just got a cam v3 and set it up to record on sound detection. I don’t need notifications but I would like to be able to listen to what was recorded. How do I do that from the app? V2.44.5
Oh and I want the recording to be saved locally to the SD card, not in the cloud. At the moment it looks like I can’t do that?
Thanks
Do you have record sound turned on in the settings?
Welcome to the Wyze User Community Forum @escapee09.cram! :man_raising_hand:
For clarification, the only settings to control what is recorded to the SD Card are in the Advanced Settings Menu. The only options to record locally to the SD are Continuous and Events Only with or without sound.
The settings contained in the Event Recording settings are for Cloud Server Uploaded Events.
