Hi there
Just got my first Wyze camera and sensor kit from Amazon. So far I’m very impressed with camera quality and responsiveness.
I have two google hubs set up in the house. I tried to get them to show me the camera and while there is a delay like most people say, mine will load the camera feed but then look almost as though it is rewinding but nothing is happening. It is rewinding what looks like 30s clips but nothing happens. It takes well over the ~20s delay people have been describing till it will finally load the feed.
Any suggestions? At the moment I’ve got it set to continuous recording on a 32gb micro SD card. The camera is in the garage on a separate network via Powerline adaptor since my garage is a separate structure and is basically a Faraday cage due to its all tin construction. The speeds I get in there though are about 25-30mbps and when I open the Wyze app to view footage its almost instantaneous.
There is currently an issue with streaming to the Google/Nest hubs, it is unknown whether the issue is on WYZE’s end or Googles end. There is some discussion about it in the thread linked below, also @UserCustomerGwen is compiling some info if you would like to provide them with the requested info.
There’s also an issue with streaming to Chromecast dongles. Worked perfectly for several weeks for me until 2-3 weeks ago. Now it starts the stream just fine to my TV for less than a minute, then buffers endlessly.
At least yours streams
Mine turns on my chromecast and tv then its like my TV has a stroke and a bunch of random indiscernible frames freeze on screen
I have to change input on the TV and close the google hub for it to go away
I have the same issue. Just got a couple of new Wyze cams that I was intending to use with my Google Displays but it just keeps trying to load… The bar looks like its rewinding like mentioned above… But the timeline keeps loadind and jumps every 4 seconds and shows a new frame. This happened on both on google display and lenovo display and also on my Shield TV.
Have there been any updates on this? Tried again a few days ago and the Google hub just sat there doing the same rewind thing for about 5 min till I finally gave up and turned it off.
