Google home & Alexa
Hi I’ve added wyze to Google home but it only picks up the cameras, no sensors and it’s unable to stream the cameras on my TV (android TV), eufycam & nest work fine
Amazon Alexa nothing comes up under skills when I search
Are both implemented?
Do either work for anyone else?
Here is a quote about the sensors
" At this time, you can use IFTTT. We’re also working on getting Alexa and Google integration up and running though. If you want to see a specific integration added, feel free to let us know on our Wishlist forum!"
I use Alexa with fire TV and it works good with the cams
Current integrations (as found in the app “Shop”, “Details”, “Key Features” section for each product):
Alexa:
Wyze Cam, Wyze Cam Pan, Wyze Bulb
Google Assistant:
IFTTT:
Wyze Cam, Wyze Cam Pan, Wyze Sense, Wyze Bulb
Cheers, Alexa I found I have to change my Amazon region to see the skill hence why I didn’t find it initially
Google home found the cams but wouldn’t stream yesterday, kept playing YouTube videos instead, today it’s working but takes roughly 90s to start streaming
Thank you both for your info
Glad you got er working
